Enkei GTA style wheels
Jordan83
I have bought a set of Enkei GTA/GNX style wheels off of Ebay and I am having a hard time finding some center caps. They are 15x7 and are black mesh with chrome around the outside.I was wondering if I could use some GM center caps but Im not sure. Any help would be greatly appreciated!!!
Jordan
I believe those wheels use a cap similar to that used in the Kirban GNX style wheels. They were black with plastic retaining "teeth". There are hard and next to impossible to find. If u are refering to the GTA (GNX look alike) GM center cap. i dont believe it will work. That center cap is huge compared to the other.
Good Luck
I had the same situation. I got the pastic ones from Kirbans. You will probably need to use some adhesive to keep them in place. I lost my front ones when the brakes heated up the silicone that held them on. I'm going to use some stronger stuff next time. These plasitic things ain't cheap.
i need some too so if you guys find a good source post back here.
later,sean
Kirbans has a set of plastic 2 2/3" diameter for $30 for four. The metal logos for the center are $22 per set of 4.
Phone 215-766-1611
These fit the GNX style wheels.
