hey guys, I am goin a little nuts here. got a BS3, wbo2 is in dp. no exhuast leaks at all. car is running pig rich, 02 correction is -22.7 at idle, hot. a/f is 13.6. problem is I will lower the number in the cell in the fuel table , the o2 correction will go down but is not consistant. for instance, if I get it down to -3.2 and rev the throttle it will go all the way up to -22.5 then 10 seconds later it will go down to -5.1. it can never stay atr that number. if I shut off the car and restart with that calibration saved, the o2 correction will be higher. what the hell is going on here?? everything is soldered and double checked. once I get it like -2.0 act af and des af is almost the same but the 02 jsut cant stay the same it will jump numbers dramatically, I know something is wrong here. I expect it to moive around a tad but not by 10 numbers.
help!
thanksd
Ralph
yes I put the in the right inj cc size for the parameters, alot the tps settings and iac numbers are right.
help!
thanksd
Ralph
