LIL6cyl
- Dec 24, 2003
I got a problem, I was driving from Arizona to Ohio and had a short in my Knock gauge. Now when I look at my logs it shows the max of what ever you set IE 10 shows 10 on the esc. what ever i set it will retard to
I dont know alot about the xfi, or what to do to fix it. There is no metal in the oil, and I think if I was running 15 DEG of knock there would be noise, or metal. could it be a bad file, sensor????
Could some one give me a new file to try. I have 83lb injectors, 3 bar map, TE63 turbo, and bored .030 Thanx Sgt. Fry
