Jan 23, 2015 #1 J Jeepen New Member Joined Jan 23, 2015 Messages 3 I am adding a turbo to my 231 jeep cant quite make out the wiring diagram at the relay is the purple wire 18 a ground ?
Jan 23, 2015 #2 G GNVenom Well-Known Member Joined Jan 6, 2002 Messages 2,084 No purple wire at the ESC. It's either pink with a black stripe, or blue. The ground is a black with white stripe and the signal out is yellow with black stripe.
Jan 23, 2015 #3 J Jeepen New Member Joined Jan 23, 2015 Messages 3 This is the diagram I was using I see the pink wire as hot but don't see what the relay is closing? ground or another positive? thanks for your help
Jan 23, 2015 #4 G GNVenom Well-Known Member Joined Jan 6, 2002 Messages 2,084 I was referring to the standard ESC on the 84-87 turbo engines. If you are using the early style system, I can't give you any advice. Hmmm I ASSumed...
