Eurothane Bushings
SS/GN
When using eurothane bushings in the rear suspension,do you tighten the bolts up tight or leave them a little loose so as not to bind upo_O .I am using new grade 8 hardware with nylocks.Thanks for the input
Kevin
Once the chasis is at ride height tighten the bolts to spec, don't leave them loose
Thanks,I was thinking of less binding and free travel.You have a good point.
Kevin
