Apr 19, 2009 #1 F Finallall Member Joined Oct 6, 2008 Messages 49 Are those interchangable? Also how can I tell the difference between the 2? Thanks.
Apr 19, 2009 #2 Chuck Leeper Toxic old bastard Staff member Joined May 28, 2001 Messages 16,806 The caps.. Finallall said: Are those interchangable? Also how can I tell the difference between the 2? Thanks. Click to expand... have the wire towers spaced differently. Even is evenly spaced. Odd is not. It's been a while, but AIRC, the bases are the same.
Apr 19, 2009 #3 U unboostedV6 Member Joined May 25, 2001 Messages 278 Also, the pole (center) piece of the magnetic trigger will only have 3 "teeth" on the odd fire unit...the even fire will have 6. As noted previously, the bases are the same. GB
Apr 19, 2009 #4 F Finallall Member Joined Oct 6, 2008 Messages 49 Found it: http://members.toast.net/rbuchholz/heiexp.html
