noticed some coolant in the oil so I pulled the heads. Drivers side gasket looks brand new, passenger side is what you see above. I'm not sure what to make of it, the fire ring seems fine and it doesn't look like combustion gases were making it past there. The plugs, pistons, and cyl heads in those cyl's don't look like they saw any serious detonation either.
Any thoughts on what caused this?
The last (and only) hg that I've blown looked like the standard blown out fire ring. Though I'm 99% certain this is the problem, theres even a little doubt that this is where my coolant came from. I'm wondering if when I lifted the heads up the gasket tore and dropped off crumbs of the gasket that I didn't notice.
Does it look like a blown HG to you?
