wickedsixx
- May 22, 2003
gt6152 with about 2 hours run time with actuator
aluminum vacuum block
accufab adjustable fuel pressure regulator
72 lb injectors
turbo tweak chip for 72lbs
modded ecm
fairly new 8" k&n intake filter 3" w maf bracket
14" k&n intake filter 3"
new K& n drivers valve cover filter
k&n set of valve cover breathers
ac delete pulley
torque strap
rjc power plate for stock plenum
stock intercooler w dutt neck
chrome turbo cover for thdp
fuel rail pressure gauge
chrome mass pipe 3"
chrome up pip with alky nozzle and braided feed hose
82-92 fbody Spohn crossmember with torque arm for 2004r
harness for 87 camaro with gn engine
turbonetics in car boost controller
houston 3" elbow and about 1' after
82-92 fbody brackets for c5 brakes new
g body brackets for c5 brakes new
hubs for the c5 brakes new
gauges below are autometer ultralite
3 3/8 120 speedo
3 3/8 tach
2 5/8 boost
2 1/16 boost new
2 1/16 volt
2 1/16 fuel
2 1/16 oil
2 1/16 water
I am working on the price list but make an offer if you see something
72 lb injectors
modded ecm
ac delete pulley
torque strap
chrome mass pipe 3"
3 3/8 120 speedo
3 3/8 tach
2 5/8 boost
2 1/16 boost new
2 1/16 volt
2 1/16 fuel
2 1/16 oil
2 1/16 water
