Here's the situation. Vacuum going into the evrv is 15. Direct Scan shows the chip is commanding the evrv to apply vacuum while cruising. I'm test driving with a long rubber hose attached to the other port on the evrv and a vacuum gauge in the car. No vacuum to the gauge. Not setting a code 32 so the ecm thinks it's working. I need to get the egr working for inspection this month. Any ideas on how to check the evrv? I don't have access to a spare. Thanks.
