exhaust housing , are there any others that bolt up?
volvoman
The Green BEAST
If any one has any info on other housings that bolt up. I am trying to do my exhaust and the TTA , TH elbow will not work. I thought there has to be something other than these two. I know that the 85-84 housings won't work either. I need the exhaust to go toward the front of the motor. I have an extra stock elbow that I do not want to hack up but if I can't find anything I will. Thanks for any and all info.
Chris
Don't know what your installation looks like, but have you tried "reclocking" the turbo? The turbine and compressor housings can be set up at any angle, just have to loosen the bolts in the center, holding the two together. That would let you turn the stock exhaust elbow towards the front, while the turbo outlet would point in the stock direction.
