exhaust mount @ transmission.... where to get one?
Blazer406
Mechanical Engineer
Hey guys.... just got my Christmas present to myself...... :D ..... a Hooker mandrel bent catback exhaust system. I cut the old system out and have started in with the Hooker..... found out my exhaust mount between the test pipe and where the catback starts...... the one that bolts to the tailshaft of the tranny.... is all but gone..... rubber has broken down and mostly disappeared.....
Anyone ever replaced that? Where did you get one... and how much was it?
I cut off the rubber part, and had the exhaust shop that welded up my hooker exhaust drill some holes on the factory brackets and bolt in some rubber strips. So I guess sort of "rebuilding" the hanger. If you're installing it yourself i'm sure you can do something similar, or you can buy one from gbodyparts as he mentioned.
