Exhaust sound or valvetrain - i cant peg..
UBER6
guys, maybe someone has run into this. 86 buick w/ATR headers/ATR external wastegate; sealed up w/permatex high temp red - has annoying "puttering" sound under passenger side floorboard when driving off..- thought it was the crossover pipe; took off and sealed it up...did all exhaust joints...; checked w/soapy water all joints...rats - still hear this putter sound - not heard at idle - give it the gas and distinct puttering...could it be valvetrain? has 145K miles (replaced timing chain/gear assy)..
same valvespring, rockers, etc...hmmm. what would be a symptom thanks for any pointers.
heads are stock...if it were a tappet sound..that would be heard at idle?
have a buddy create some backpressure by blocking exhaust pipes with shop rags while you listen for exhaust leaks
Bottom of cyl #6 exh. manifold gasket leak?
Felpro header gaskets suck!
