Maybe I am missing something.....
First let me lay the groundwork.....
Rollmaster makes timing sets with "oversized" gears/sprockets for the people that have had their engines line bored and now the stock timing chain/gear setup leaves too much slack.... because the crank centerline has been mooved up a little as a result of the line boring.......
TA's site says the chains are the same between the sets.....and that the sprockets are made slightly oversized.... to accomidate the slack.
OK... here is where I am getting lost. First lets agree that the number of teeth (per sprocket) is fixed... and cannot change. The crank gear will have 1/2 as many teeth as the cam gear... therefore spinning the cam at 1/2 crank speed..... which cannot be any different.... it has to be that way.
Now.... if the chain is the same.... then the pitch or distance between each roller is the same.....and if you make the sprocket oversize....... how do you accomplish this without changing the pitch of the chain? It would seem to me if the sprocket grew in diameter......that if the tooth count was the same..... the pitch would have to grow for the chain to mesh properly with the sproket.
If they said.... each chain is matched to each different spocket "set" I would agree it is possible to manufacture a slightly longer pitch chain to accomidate the slightly longer pitch on the sprocket.... and it would work fine...... but that is not what they say...... they say the chains are the same.
Can someone explain this? - Sorry... it is just the Mechanical Engineer coming out in me..... I need to know why stuff works the way it does..... We (ME's) aren't wired to just accept an explanation and go about our way..... just doesn't happen..... LOL
