I would say that we are very lucky that TA and Champion are even making these heads for us given the limited market.
If either company were to develop a new head design I think it would be interesting to see a head with some of the modern LS characteristics incorporated into it. You would obviously need a different intake to accommodate the port design.
Since you pictured a LS head for reference I thought these flow numbers on stock untouched 243 heads would be of interest. The intake numbers are on par with the Buick heads.
Casting Number 243
Head: 2001 LS6 5.7 Liter Passenger Car
Material: Aluminum
Part Number:
12564243
Combustion Chamber Volume: 64.45cc
Compression Ratio: 10.5:1
Intake Port Volume: 210cc
Exhaust Port Volume: 75cc
Intake Valve Diameter: 2.00 inches
Exhaust Valve Diameter: 1.55 inches
Stock Head Flow Numbers
Chamber 64.45 cc-------0.100---0.200--0.300--0.400---0.500---0.550---0.600
Intake 210 cc------------62------126----184----224-----251----256----257
Exhaust 75 cc------------57------108----143----163-----176----180----183
LS style ports with some nice port work and a matching sheet metal style intake with Improved plenum design and
a wilson style 90* L bow would open up some possibilities. The big TA/champ intake may even be able to accommodate
this style port. I do not have mine yet to measure.
300 cfm ports with good airspeed and strong low and mid-lift flow numbers
using smallish <2.02" intake valves I feel would be do-able.
Usable power power range could easily be extended to 7000 rpm
or the combo could be set up to max out a compressor limited engine at
a much lower pressure ratio which would help turbine pressure to be lower,
compressor discharge temps lower and a cleaner cylinder fill.
win,win,win.
I measured the TA heads valve angle at 10-11 degrees and I think this would work very
well with an even taller raised runner style port that the LS heads have,
The taller the port the better the flatter valve angles will work due to the air being able
to get around the short side radius better.
I feel this is part of the reason the exhaust port flows as well as they do....once the air
gets past the valve it has a nice upward slope that gives the air an easy path to follow
and the shortside and long side radius gently turn to get the air out....you can feel it
just running your fingers through the port.
Anybody know what the valve angles are in the stock and the champ heads?
