Ext Wastegate
HOTSIX
Ran outta hand cleaner
Who has one and how did you install / plumb it itno he vac and exhaust ?
What did you do with the existing vac lines / wastegate setup ?
I have been considering an ext wastegate for some time now and I am part way thru an install of the JS Manuf IC intake. Thinking ext WG for better and safer boost control.
i put my on the pass side of the crossover and just ran a press line off the turbo to my bleader valve and from that to the wastegate.
Did you vent the exhaust from the WG to atmosphere or pipe it into the DP?
If you piped it into the DP what did u use....some say theres a cracking issue if u dont use some type of flexible piping....im curious about that part.
:rolleyes:
Im looking at the Deltagate or the Tial ext. WG......
no i just dumped mine out to the ground its real fun to scare the hell out of people walking when i hit ful boost sounds like im dragging somthing ill pipe into theeghuast some day , maybe.
