External cooler question
smallv6
Still in Block Learn Mode
Is there a stand alone unit out there that I can run alone without utilizing the cooler built into the radiator?
I have seen the pts xtreme cooler, would this be ok on it's own?
Thanks.
OK :D , I found them. Which one would you suggest?
Thanks for your help ;)
WOULD CALL THEM TO GET THEIR RECOMMENDATION
FROM WEBSITE:
Q. Who can I talk to if I have specific technical questions regarding FLUIDYNE products?
A. You can speak with our staff at either our California or North Carolina facilities. The phone numbers are - California = 1-800-358-4396 North Carolina = 1-888-358-4396. Both are toll-free numbers.
Calling them direct is the best way to make sure you get what you need. :)
HTH :)
We have a really sick unit with cooling capacities of an unreal nature, but I would never run just the one. Fluid to heat dissipates temps much more efficiently than air will. The add on coolers are just as stated, ADD ON. Run both and you will be much happier for sure. Mark :D
