External Pump mounted on alum plate
KWIKR 1
any drawbacks to mounting external pumps on alum plate ? going to have the the pump mounted underneath trunk pan with 4 rubber isolators . should the plate be grounded ?
i see nothing wrong with doing so. I would use 6 rubber mounts just so you dont have some much load on the 4. Spreading out the flexing and vibration.
no need to ground it with a seperate ground IMOP either.
please keep us posted on your new setup
Do you also run an in tank pump?
I run the same pump with no intank. These pumps will suck a golfball through a garden hose. :p
In his initial statement he uses the word pumps. Is his picture a picture of a pump and a filter or is it a picture of two pumps?
Thats appears to be a pre filter. It's suppose to run a pre and post. I would imagine his post will be down the line in the frame rail. Thats how I did mine.
I would use rubber mounts on the plate, filter and pump:)
No in-tank , just the weldon 1100a . yep..... a post fillter will be installed . i heard these pumps are not to loud . also will have a kenne bell bap installed and controled by the fast xfi .
Got her in and she looks pretty nice . :)
