External Waste Gate
USMC_Turbo6
What are some of the brand of external waste gates do you guys run? Has any one ever run one of the eBay waste gate and if so, how did it work?
I use a Turbonetics Evolution works good for me I'm under 500hp
question is what pipe do you have or do you plan to do the fab workto make it fit an old pipe or take it off the header?
the one turboburick linked will bolt on replace for ATR, deltagate or tail 38 setup pipes but it just cant flow enough for your combo
youll need a bigger gate ,
precision makes a 46mm gate ,pw-46
check with Cottons or Hartline for one
the pw 46 comes with vband connections and the vband flanges so you can fab(weld) it onto an older down pipe
First of all I want to say thanks for all the help. I have a TH and ATR down pipe. So I can get what will work the easiest for me. I have a new stroker that is going in the car that I have very high hope for. So I need something that's going together the his done from the jump.
