Craig Smith
That was easy!
- May 25, 2001
Rob,
If the engine is misfiring at all, it will definitely cause the O2 sensor to be inaccurate. Sounds like you're on to something now. Like I said before, closing the plug gap and seeing a noticeable performance increase generally indicates the need for a stronger ignition. On the valve spring thought, keep in mind that for every pound of boost you run, you should multiply that pound of boost by the surface area on the back side of the intake valve and subtract that number from the seat pressure on your valve spring. If you make some quick calculations based on this, you can see how easy it is to wind up with very little seat pressure.
Hope you'll get this all figured out!
Craig
Craig
