Just got back from the States and have jet lag so I thought I would post about my F body radiator install. When I first got home, it was 90+ degrees. My wife and I decide to go for a ride through the mountains and got stuck behind a truck going about 20 mph up the mountain. Needless to say I was pushing over 200 degrees without the a/c on!
The next day I installed the Fbody radiator and a set of dual fans for Gbodyparts.com. The radiator was a drop in itself. The fans needed minor trimming to fit flush to the core. The fans did fit the GN radiator perfect. I mounted the tranny cooler under the front bumper and removed the oil cooler and lines. I filled the radiator up half way so that it would heat up and test the fans. WOW! The fans cut on and the temp immediately dropped back down to 167 degrees! I couldn’t believe it. I topped off the radiator and took it for a test drive with the AC on and it would not get over 173 degrees. This is with a front mount also. It was 92 outside and went downtown to hit every red light. I highly recommend this upgrade! Cheap, easy and very effective!
