Sleeper1987
3.8L of Fun!
- Jun 11, 2006
1987 Buick Turbo-T
RARE color yellow/beige exterior (1 of 160)
tan interior, buckets, console, moonroof, twilight sentinal, concert sound, power windows, posi, 122,000 miles, complete new A/C system, alternator, battery, Sony AM/FM CD and speakers 15x8,15x5 Weld pro stars w/ 275/60/15 Goodyear eagles rear, 205/75/15 front
SOUTHERN CAR NO RUST~!
Mods:
stock block, crank, rods, pistons
turbo saver biggie oil filter relocater
K+N filter
ported heads
206/206 cam
LT-1 springs
009 injectors
fuel pump(inline nos hipo same as t-rex vortech)
Red Armstrong volt booster and 93 chip
Casper hot wire
TA-49 turbo
adjustable wastegate and fuel pressure
ATR 3" down pipe
3"test pipe w/dump
Cotton 3" single shot exhaust
front mount intecooler
ramcharger fans
B+M megashifter
TCI streetfighter 200-4R transmission w/TCI streetfighter torque converter
trans cooler
torque strap
boxed upper and lower rear control arms
RR air bag
polyurethane bushings
Auto meter tach, oil pressure, water temp, fuel pressure and boost guages
Scanmaster 2.1
FACTORY OPTIONS
AR9 seats, reclining bucket
AU3 power door locks
A01 tinted glass
A31 power windows
A90 power trunk release
BD1 rocker panel moulding trim delete
BS1 acoustical insulation pkg
BV8 ornamintation exterior door lock cylinders
BW3 ornamentation extra roof window trim (painted)
BX5 ornamentation ,exterior moulding roof drip (painted)
B24 side window reveal mouldings (black)
B48 trim package luggage compartment
B71 wheel moulding (colored)
B72 ornamentation ,exterior moulding belt reveal (colored)
B77 ornamentation,exterior moulding w/s reveal (colored)
B79 ornametation,exterior rear end
B88 moulding body side (custom)
B89 ornamentation, exterior moulding,RR window reveal
B91 exterior moulding, door edge gaurd (colored)
B94 ornamentation, exterior emblem ,body,var 1
CD4 windsheild wiper system (pulse)
CF5 roof,sun,glass sliding,elec
C18 arm and blade WSW
C60 HVAC system,air conditioner frt man controls
C95 lamp, intr,roof,courtesy and dual reading
D55 console, frt compt,floor
D64 mirror,l/s,rh,sunshade,illum
D68 mirror o/s,lh&rh,rem cont,painted
D71 gear speedo driven
D85 stripe,body side, lower accent
E5Z speedo adapter delete (analog cluster only)
FE3 suspension system (sport)
GU6 axle rear 3.42 ratio
G80 positraction,limited slip
G87 ring gear 8.50 10 bolt axle
J41 brake system,pwr,frt disc,rr drum,cast iron
J5O brake system power
KO9 generator 120 amp
K34 cruise control automatic,electronic
LC2 ENGINE,gas,6cyl,3.8L,SFI,V6,TURBO,H.O
MW9 Transmission,auto,4spd,THM 200, Conv clutch
MXO merchandised,trans,auto provisions,O/D
NA5 emissions system,federal, tier 0
NP5 steering wheel (leather wrapped)
NQ5 cap steering,wheel,horn,deluxe
N33 steering colum,tilt type
N89 wheel" turbo" aluminum
QYH tire all p215/65r15/n wol r/pe st tl HWY
TL6 Grille (black)
TL8 ornametation ,exterior,hood, (3.8 SFI TURBO)
TT5 headlamps halogen 4
T47 HOOD (TURBO)
T63 headlamp on warning provision system
T82 headlamps auto on/off/cont
T83 headlamps,dr,(special)
T93 lamp,tail&stop (special)
UA6 theft detterant system
UQ1 provisions for stereo
US7 antenna,power,painted radio
UW4 speaker system,6,dual frt dash mtd f/d,dual
U23 cluster,inst,trim odom
VD6 bumper provisions,frt,aluminum
VD7 bumper provisions RR,aluminum
VK3 license plate mounting pkg
V73 Tow hook delete
WO2 package SPORT APPEARANCE
Y56 merchandising package GRAN TOURING
19A stripe color accent two tone med gray met/black
54U Primary color exterior, MED FLAX (91) YELLOW BEIGE
6YX spare tire delete
62B Trim comb, light saddle cloth
62I trim int light saddle (I)
Now for the problems the car has has a poor job of having the door braces removed seats need covers , maybe a headliner later down the road
and the tranny slips when it shifts into 2nd car has normal dents and dings all over,Overall condition out of 10 would be a 8 in my opinion. car runs strong despite the tranny issue and is drivable trans does fine once in drive/overdrive.It ran a 8.32 in the 1/8th with these problems so high/mid 7's are a given when repaired and the boost is turned up some.
I really dont want to sell this car but im unemployed and this is my only car and i cant afford to fix it so it has to go as much as i hate it.
new parts added in the past 2 weeks
fuel filter
fuel tank cleaned
fuel injectors cleaned
oil/filter changed
trans fluid/filter changed
car cleaned up
radio fixed
gauges fixed
ASKING 10,500 obo or trade car is located in Chattanooga ,Tn
Mods:
K+N filter
ported heads
206/206 cam
LT-1 springs
009 injectors
Casper hot wire
TA-49 turbo
ATR 3" down pipe
3"test pipe w/dump
ramcharger fans
B+M megashifter
trans cooler
torque strap
RR air bag
Scanmaster 2.1
FACTORY OPTIONS
A01 tinted glass
A31 power windows
TL6 Grille (black)
T47 HOOD (TURBO)
V73 Tow hook delete
fuel filter
fuel tank cleaned
oil/filter changed
car cleaned up
radio fixed
gauges fixed
