F/S Hardly used Buick stock intercooler $350
87GNT
Buick stock intercooler for stock location intercooler installation. Intercooler comes with a very nice black finish. The wrap around shroud (shown in pics) is aluminum and very well make.
This does have the Dutweiller style neck on the unit. The shroud on our intercooler can open up to 5-1/2"'s to allow even more flow. This unit wraps around your sway bar and does not hang any further down then your factory IC scoop would on any 86-7 turbo buick.
Measurements: 13.5" wide core, same as the factory. Core Height is 15-1/2". Thickness is 3".Inlet is 2.5 " as is the outlet to your up pipe.
Installation Instructions: If you have a stock IC in place the only thing you are doing different is installing our bracket. (Compared to stock it is the same dimensions except the bottom is cut)
Our intercooler has the same bolt hole locations compared to stock!
See pics for unit description
