Jan Larsson
- Nov 22, 2001
Just to let you all know I sent the feed and return fuel lines (just the hard lines attaching to the fuel rail and the fuel pressure regulator and not the rubber lines) to classictube.com to have them reproduced.
Also sent them the powersteering cooling line to reproduce for me.
These will be avalible shortly so I'll update you all with the part numbers when they got them done for me, I'm getting them done in stainless steel but htey will be able to do them in OEM material as well.
Most of you know they already carry our transmission cooler lines. The power steering lines (both the hard line and the rubber line).
They also have the hard vacuum lines but not seen them so not sure what they look like and how they compare to the OEM lines.
