Guys,
I installed a VDO oil pressure guauge on my TTA recently (I had it of the GN), and it seems like the pressure is 7+ lbs different compared to the factory gauge on the dash?
At hot idle the VDO is just above 10lbs (probably around 12lbs) where the factory guage is showing a little over 20lbs.
I plumbed the VDO in a T by the turbo feed like (just like a buick)...
I did some searching and seems as most rely on the factory piece? Is this what I should do?
I know 12lbs at idle is not bad... just like the TTA readings better
