failed emissions (nox) im240
  • Thread starter Thread starter azturbo
  • Start date Start date
A
azturbo
Guest
who sells smog chips ? does the xstender chip have egr fuction my set up is stock block ,cam, heads, v4 ,49turbo,tranlater+ ,3.5maf ,th down pipe,boost cmd.,msd50 inj.,
emissions
How much did u fail by? Do u run alot of racing gas?
Make sure u check your egr line to the egr sometimes it comes off
and you'll fail cause the egr is'nt hooked up.
U can run 30miles with the gas gap off like on the freeway. I
Know it sounds stupid but it works. Make sure u put the gas cap back on when u go threw emmissions. The other thing is to run
some Alcohol in the gas tank this will get it to pass to.
How many miles is on your turbo regal?
Don't think that there is an egr function in the extender because I never notice the egr counts on tlink like I do with other chips
Bob
Extender chips have NO EGR functionality.
