Well, after almost a month of happy motoring, it looks like I'll be pulling my motor to re-ring it.  I think I have a grasp of what went wrong and why, but I want to run it by the folks here to make sure I have the right understanding of the cause and it's effects.
First of all, I should mention that I was running in closed loop mode, with a large potential fuel enrichment number. This was done at my tuner's suggestion, and "seemed like a good idea at the time", even though we had it tuned to the point where, in practice, very little O2 correction was needed.
Secondly, I need to mention that I had my WBO2 sensor mounted in the mid-pipe, in front of the cat. My exhaust has four components: downpipe, mid-pipe, cat, and cat-back. The cat has V-band clamps attaching it to the pipes on either side, but the downpipe-to-mid-pipe connection is with a more traditional three bolt header flange.
Here's what happened: several of the downpipe-to-mid-pipe bolts loosened on me, causing the connection to separate by a half inch or so. Since the O2 sensor was located in the mid-pipe, on the wrong side of this big ol' exhaust leak, it was suddenly reading leaner than it should have (or so I'm theorizing). The ECU compensated for this by kicking in a lot more fuel. Since this happened at freeway speeds and positive boost, things got ugly quickly: the motor began to ping quite a bit. I had to nurse it along a little ways before I could pull over, and by that time I believe the damage was done.
After having the truck towed home, I pulled the plugs. Detonation had almost closed the gap of the plug in the #1 cylinder and cracked/split its insulator. I changed the plugs (the other plugs looked fine), bolted the exhaust back up, and tried starting the motor; it ran very rough, as if at least one cylinder wasn't firing (actual A/F was around 10.3:1 while it was running in this state, while the target is more like 13:1). I did a compression test, and my compression in the #1 & #2 cylinders was 90 psi, and compression in the #3 & #4 cylinders was 62(!) psi. Yuck! I'll be doing a leakdown test before I pull the motor, but I am pretty sure I am looking at broken rings in each cylinder.
Does this sound right? I have an o-ringed deck, and really don't think I simply took out the headgasket (somethign I have experienced). I haven't had this happen before, so I'm trying to learn as much as I can from this -- everything from where NOT to mount the O2 sensor to how much fuel correction NOT to dial in But I am most curious about the connection between excess fuel, detonation, and broken rings.
Thanks for whatever additional insight anyone can share.
Jeff
  I think I have a grasp of what went wrong and why, but I want to run it by the folks here to make sure I have the right understanding of the cause and it's effects.First of all, I should mention that I was running in closed loop mode, with a large potential fuel enrichment number. This was done at my tuner's suggestion, and "seemed like a good idea at the time", even though we had it tuned to the point where, in practice, very little O2 correction was needed.
 But I am most curious about the connection between excess fuel, detonation, and broken rings.Thanks for whatever additional insight anyone can share.
Jeff
  Detonation as we usually ref it occurs after the mix is lit off, where a pocket(s) of unburned air/fuel charge suddenly auto-ignites from heat and pressure, not from the usual, progressive flame front burn.
