Hawaiian Turbo
POWER'D BY BUD LIGHT
- May 25, 2001
I was looking at the timing table while cranking and it was going from 500 over to 7500.  I presume that is what's causing the hard starting... dumping in fule as if it was really at 7500 rpm. What would cause this? I checked rotor phasing, and it's pretty close, rotor facing at number 1, crank at 52, reluctor in the middle of pick-up. I'm running an MSD 85551,and have the crank trigger for the FAST hooked up to the two pick-up wires from the dist.
Any ideas ? Should I just get a crank trigger and forget about it?
Thanks, Paul
Thanks, Paul
