I've noticed that now my fan isn't kicking on quite frequently. Often, it runs for about 5 minutes after I shut off the car (even with a 160 stat), other times it doesn't run at all. SM is showing coolant temps in the 180's and 190's when cruising in light traffic.
I suspect the fan delay relay is bad.
Are these only available through GM or a GM supplier, or do the auto parts retail chains sell these relays (i.e. PepBoys, Strauss, Auto Zone)?
Could it also be the fan temp or coolant temp switch?
S.
S.
