Fan for AC and the heater stopped working
GSX-PKV
I noticed that the fan for AC and the heater stopped working. What should I look for to correct the problem. Thanks! Paul
Make sure it has a good connection at blower motor under hood. does it work on high speed?
The fan does not work at any speed. The connections under the hood seem solid and I'll check with a tester to see if it is getting power. Thanks.
Checked everything under the hood and it all checked out. Just for the heck of it - using the barbarian mechanic school fix - I hit the top of the fan housing a couple times with my fist and the fan stated working :) Hopefully it will keep working.
