Fan is always ON...?
KEVINS
Maybe this is a coincidence but I just R&R'd my tranny AND installed DirectScan and now my radiator fan is always ON when the key is on. Even if the motor is not running and it has been sitting for a week...
Any ideas where to look to cure the problem?
thnx
ks
:confused:
FAN ON
Kev, the last one I had to fix was due to the AC press. sw being FUBAR. It was the sw. directly behind the compressor on the hard line. I changed it and WALA!! it worked as it should.
HTH,
ok, I unplugged this switch and the fan turns off. I plug it back in and the fan goes back on. Based on this I'm guessing that the switch Chuck mentioned is bad. So if I remove this switch am I going to lose the pressure in the A/C system or not? If I am then I'm leaving it alone..
ks:confused:
Chuck, or ??,
can sombody answer this question for me please?
ks;)
I believe that switch is on a schrader valve. It simply closes when the pressure goes up and shorts out the wire to kick the fan into high speed mode. Sounds like it is staying closed now.
