I'm having an issue with fouling #1 cylinder and have been through the following to trouble shoot thus far to no avail;
1. Changed lead wires
2. Changed plugs 3 times (NGK TR6, TR7-IX, Autolite AR 103)
3. Changed coil packs
4. Swapped to an alternate EDIS-8 module
5. Compression test (All good)
6. Leak down test (also good)
7. Checked timing with spout in and out with reading on FAST dashboard.
8. Had all injectors in to be tested and flowed and they all check out 100%.
I've got the intake manifold being changed right now from a custom short runner intake I had on to the stock intake I know there was no fouling issues with, but there wasn't any evidence when I removed it. I also have a Kenn Belle BAS that I was running and am disconnecting that as well. I have a 3 bar MAP in now and a 2 bar MAP on the sidelines and so I can change MAPs to see if that's possibly it. I keep fouling plug in cylinder #1 and it comes out black and sooty, not wet. So, there's some sort of combustion and ignition going on although the ignition may be a problem? I've been through every inch of the ignition and components and don't see a problem so I'm wondering if it's a FAST issue, because that's the one component I haven't tested or sent back to FAST for testing.
I did have this same FAST setup on my car with the Procharger on it and there was never a plug fouling problem. Once I get the intake and all back together, I can test spark. One other thing, I did purchase a new MSD DIS-4 unit but that may just exacerbate the problem I'm having..?
Any suggestions?
Any suggestions?
