Alot of people are having trouble setting some of the warm up and afterstart settings. I have put together some generic AE fuel and warmup/afterstart file packages that can be pasted in your present tune. Please use caution as the tune could be way off depending on injector size and each combo is a bit different. You load your existing GCT. then use the paste from file tab in the top left of the file menu.. Any issues please feel free to comment. You will have to 1st unzip the files and place them in your ICT folder within c-com.
(correction these will not work in classic fast because there is no paste to file menu for appended files, but should be compatible between XFI 1.34 and 2.0) The individual files should work with classic fast not the packages. (appended means more hiddenfiles within one file name)
