G
gm2bad
Guest
Hello,new to this forum I was told you guys might be able to help.I just bought a new fast efi system that i am having trouble with on a 94 Mustang GT.The problem is on a 94 GT the TFI module is on the pass fender not the dist and when I tried to hook up per instructions I get nothing,the connections are the same I was told.Called Mike at Fast and he said he wasn't sure about a 94 so I purchased a 93 MSD pro billet dist.Simple just make connections per instructions and bingo,nothing still the same no spark.The one thing is if I disconnect the spout wire I get spark but no ignition because of no rpm signal so I don't get fuel.And if I connect all the old wires with the old dist and just tie in to the specified wires I get all readings and it runs but I still have the old computer in so I think it might be running off of the stock ecu timing settings.Thanks for any help Gary.
