i just got my car running on sunday, had to adjust the iac way up to deal with the cam (at least thats what i think anyway) and it was idling nice and smooth at 750-800 rpms, but the timing was too advanced, its at like 20-25 spout out. i was going to change it down to 10* spout out, but it started to bubble water out the radiaitor because i had the cap off, so i shut it off, then noticed i had to leave soon for work.
heres some specific problems:
1)when i got home after work i warmed it up and the car wont run with the spout out, otherwise it seemed to be idling pretty well at 750-800 rpms. i was trying to set the timing at 10 degrees. i didnt change anything since i went to work. need some help here.
2)car is very hard to keep running right after it starts. it jumps around and wants to die right after startup, i have to pump the gas to keep it going, after about 5-10 times keeping the revs up, it will idle fine on its own.
3)after it was warmed up tonight, it died when i pulled the spout. then after awhile, it didnt want to run AT ALL after startup, no matter what i did. i messed with the afterstart enrichment, and various other things, but nothing seemed to help much at all. it was at 180 degrees.
combo:
94 mustang GT
337ci V8
AFR 205
unknown "turbo" cam kinda "big"
T76 single turbo kit
86# injectors
combo:
94 mustang GT
337ci V8
AFR 205
86# injectors
