I an tuning the fast program in my car. How do you determine what is a good timing program througout the entire grid. With the fuel tables you have the 02 corrections to tell you if your too rich or lean. You also can see the black smoke or smell the fuel. With timing and no boost what is the proper timing from idle to 3k rpm or driving without boost. When you come into a boost situation many posts have said dont use more then x degrees at this lbs of boost or with this octane fuel. But what about all the other rpm ranges you will see? Thanks
