>>I am an extreme noob when it comes to this side of things (the computer and tuning)
I would highly recommend taking some time and learning how it works. The computer is great, but if you don't know how it works then you could (minimally) be missing out on some performance! I would do some reading- look at the FAST website, for starters, and maybe some magazine articles and such. Oh yeah, and read this forum! Lots of good information here.
>>Does the car run in closed loop when it first starts up and then switches to open loop and thats when it starts getting info from all the sensors and such.
No, the opposite. You have to wait for the O2 sensor to heat up, and for the engine to get up to temperature, before you will get meaningful readings from the O2 sensor. Before this, it will be relying on the pre-programmed parameters to "blindly" keep it running.
>>It runs solely off the computer tune at first though right?
It always runs off of the computer tune- sometimes it just slightly adjusts the mixture a bit to make the O2 sensor happy. But it is always looking at the internal tuning tables first.
Having an open exhaust makes it keep compensating indefinitely with more fuel because it thinks there is way to much air for the amount of fuel right?
That's why the point has been raised about how far up in the header you can place the O2 sensor. If you put it too near to the outlet, you will get raw air from the atmosphere mixed in with your exhaust, screwing up your O2 readings. If you can put the sensor far enough away from atmosphere, you can probably run fine.
This begs the question, however about the car- are you only going to be racing it? Most guys here run a full exhaust, so the sensor placement isn't much of an issue. If you can't get it far enough up the collector, I'm not sure you will even be able to get reliable readings from the O2.
>>If this is the case (lol which probably is no since i dont really have much of a clue) Is there a way to keep the car in closed loop all the time so that I can atleast drive the thing for now? Its been over 2 years
Once the sensor is warmed up, you can run in closed-loop all the time. I think you would hear a unanimous recommendation from the other readers, however, that you should tune your VE tables so eventually the O2 sensor is only making very slight corrections, and the engine isn't dependant on the O2 just to keep running. Only then will adjustments to the AE etc. be meaningful. That is to say if you can even get the O2 to function! Can you add some length to the exhaust system just to dial in the FI?
-Bob Cunningham
bobc@gnttype.org
