I am new to the board and I just wanted to say that half of my questions have already been answered from reading through it. thanks for that!
On to the questions:
-With the FAST, should I be running a vacuum referenced FPR, or just run a constant pressure? I am using 29lb injectors (at 45psi) and flowing them at 58psi.
-Should I increase the injector size in the fast to reflect that I am flowing them at 13 more psi than they are rated, or just adjust the VE table to suit them?
-Any pointers on the spark tables? I have 16d at idle increasing linearly to 34d at 3000 and staying there the rest of the way up. This is at all MAP ranges. I have heard that at higher vacuums (cruising) you can run more timing although I can't find any info on it.
-Is there a quick and easy way to figure the proper amount of AE fuel in the various tables?
Sorry for the huge post, but I am new to all of this and still learning. Thank you for your time! I can send my tuneup file and datalogs if need be.
-Aaron
-Aaron
