Spooled231
- Jun 21, 2001
Hey Guys,
I ran into a slight problem at the track on the last run. The voltage has always been a constant 14.0 to 14.3 at all times, idle and WOT. On the last run at 5600 rpms in 2nd gear, voltage drops like a rock to 12.2 at the top of 2nd 6200 rpms. As I go into 3rd gear, it was at a constant 11.8-11.7 volts until I let off the throttle then procedes to jump back up to 14.1 going back to the pits. One thing that is really weird....the injector duty cycle didnt change at all stayed at 75 to 80 percent at all times during the entire turn and the A/F ratio was at its target of 11.5 What puzzles me if the voltage drops...the inj duty cycle should have gone up. I know that for a fact cause it costed me a motor a couple years ago before I had the adj volt regulator. The car didnt lay over at all during the run so I couldnt feel anything. If yall want to see the log, I can email it out.
John Martin
10.98 @ 121.7
6.93 @ 99.11
John Martin
10.98 @ 121.7
6.93 @ 99.11
