Rickerbucks
- Feb 18, 2003
Can someone give me there impressions.
For the last 6 weeks I have been pottering with the FAST. I sufferred from some problems that just did NOT want to go away. I would get decel popping which I eventually solved by increasing my VE tables to about 80 'ish and I also had popping whilst holding the car at cruise levels. The AFR would be about 12.5 to 13.5 whilst this was happening.
I would also get an intake backfire sometimes on tip in. Logging also indicated a lean spike on tip in. That being said, once the car was up into the mid to high range it felt reasonablly good.
None-the-less, driveability was a major issue.
So a buddy came by to give me some time. He has an 8 sec stang and although has not worked on a lot of cars, he has spent a LOT of time with his own.
We go for a drive and he richens the VE tables up A LOT. I mean a TON. Mid range VE is about 90. The AFR is reading 9 -10's but there is absolutely no denying that the car is rtunning very well. We may have to do a little more tuning at idle as it is a little rich.
We of course is saying, "this doesn't seem right. The VE numbers are WAY to high and the AFR reads really rich but..." I do NOT have black smoke pouring out the back. We pulled a plug and it looked great.
BUT here is the variable. The car has been burning oil - this was on a freash rebuild. In addition, at one point I pulled the O2 and "cleaned" it with WD40 which I have now been told is a 'no-no'
So can anyone provide some insight. Is the O2 faulty? Is there some calibration of the AFR/ wideband and the VE tables that are out of sync?
Or is it a case of "whatever works, don't worry about it?"
Thanks guys
Thanks guys
