DOHC Vobra
- Mar 11, 2002
Just wondering if anyone's had an experience similar to this.... I recently installed a FAST ECU onto my '97 Supercharged Mustang. I created a custom adapter to use the stock engine harness, and so far, everything seems to have gone well (the car starts and drives well).
Now for the wierd part, for some reason or other, I'm having to put numbers like 100-110 in the lower portion of the VE map just to make the car idle. Any lower and the car starts to go lean. (BTW, this is with a target 14.7 a/f ratio in the A/F ratio sceen)
Is it just me, or do those numbers sound whacked out???? Any ideas what might be happening??? I've checked my injector size (lb/hr setting) and it's correct...
Thanks for any info!
Justin
'97 Cobra Coupe #35
http://www.guieectuner.com
Justin
'97 Cobra Coupe #35
