Help identifying turbo
lz87gn
Just bought my first GN. It’s an ‘87. Have no info about car. Trying to learn turbo Buick and identify parts on car so I can get it tuned with TT chip and not hurt anything. Have been researching. Think it may be TE44. No tag or info plate. Has Garrett M 24 L .60 A/R compressor housing. Precision turbine housing. Tried to remove down pipe to see A/R had Allen head bolt strip. Compressor wheel is 12 blade 58mm inducer 75mm exducer. Has 3705-1 engraved in bottom of outlet of compressor housing. Any help would be greatly appreciated!
Pictures....
Comp cover, ex housing and pull the inlet pipe and take a pic of the compressor wheel.
There's people in here that know where the nut on the compressor wheel was made. Hahaha
Pictures....
Some version of te44 as you suspect with 58mm inducer.
Pull the turbo or downpipe and study the turbine for the full identity.
Got the down pipe off. It’s a .63 housing. I think it will be nice on the street. So far I have found the car has LT1 MAf with translator, BGC intercooler, 60# injectors, stock ported heads and intake, and a nice stall converter can’t wait to get it optimized for my driving pleasure😁
Most likely an 11 blade never heard of a 12 blade compressor, (count the blades again) 58/59mm billet compressor wheels are usually pared with a 58/62 or 65mm turbine , the biggest turbine wheel shoved in the .63 housing is a 68 but unlikely with that small a comp wheel
