Roland Black
- Dec 20, 2001
I recently had some problems with my WB02, and was saying bad things as I thought I was going to have to buy another one along with the calibration diskette. It would show AFR of 9.54, yet there was no cloud of black smoke behind me..... driveability was down also. The problem would come and go.
I pulled the engine compartment connector apart to check for corrosion, bent pins, just anything that might resolve my situation. Visual search resulted in nothing. I sprayed both connectors with wd40 before re-connecting the harness.
Upon fireup, problem was gone....... truck runs smoother, stronger, and spoolup is quicker, and it's been over a week with the same positive results.
For those that are having weird 02 readings, try the wd40. It just may help your situation.
