Try this first and see if it shows its ok:
Now that your serial device is connected to the Keyspan adapter, you should check to see if the
Keyspan serial port is installed correctly.
To do this, open the Keyspan Serial Assistant (in Start menu -> Programs -> Keyspan USB
Serial Adapter -> Keyspan Serial Assistant). When you open the
Keyspan Serial Assistant, you will see the following window:
the Keyspan Serial Assistant window
If your Keyspan hardware and software are installed correctly, you will see your adapter in the
'Adapter Status' tab box. You should also see the COM port number (ie COM1, COM2, etc.)
and the COM Port Status.(IDLE or BUSY).
The COM port number and its COM port Status message are very important to configuring
your serial device.
The COM port Status is the state of the Keyspan serial port. All serial ports have two states,
BUSY (aka "In Use") or IDLE (aka "Available"). When serial port is IDLE, the port is available
for use by any serial device's software. When a COM port is BUSY, the serial port is in use by
software and therefore not available to other programs.
The COM port number is the address of the Keyspan serial port. In order for any serial device to
communicate via the Keyspan adapter, that serial device's software must be told to use the Keyspan
COM port number.
If you see your COM port number and its COM port Status, proceed to Step 4. If you do not
see either of these items, proceed Problem Solving section in this manual.
Here is the complete manual if you lost it or something, the leds should tell you whats up also.
http://www.keyspan.com/downloads-files/usa19hs/docs/KeyspanUSA19HforWindowsv34.pdf
