SignUp Now!Here's the scoop. Boost control can be ran 3 ways.
The first method is similar to the factory ecm. It is "Open Loop" mode and pulses the wastegate solenoid whatever percentage you program off of the boost table using TPS vs MPH
The next method uses the MAP sensor and pulses the wastegate solenoid on and off to maintain a certain percentage of your MAP scale (i.e. 50% on a 300kpa setup would be 150kpa or a little over 7 psi. This is similar to "Manifold Mode" on an Innovative setup and is prone to overshooting.
The last method uses an Analog input and pulses the wastegate solenoid on and off to maintain a certain percentage of the analog's 5 volt range (i.e. 50% would be 2.5 volts at the sensor). This is similar to "Wastegate Mode" and IMO is the most accurate.
There are a lot more details that would be too lengthy to post. I suggest contacting your vendor for specifics.
Am I to understand there is an updated version of FAST XFI that has closed loop boost control?
what about the vendor you purchased your XFI from, are they not able to answer all your questions, or help you with it?anyone know?
