How much cranking fuel do I need with 83lb injectors. I just want a rough idea of what my numbers should be at what engine temp. Should I have more as the temp gets colder ? This is for an 86GN
You probably have too much overall, yes more cold, average rule is 300% idle PW for a hot cranking fuel, you probably have 1.8ms idle x 3=5.4 ms hot, for gas, e85 might need a little bit more.
This is a e-85 car and starts right away and stays running after first crank and ANY temperature, when I do run gas i just highlight the whole graph and lower it a little....I too agree that it looks and prob is on the high side ,but it works,so Im not gonna mess with it
