FAST XFI Dash/Datalogger
HighPSI
Moderator
Staff member
Just wanted to share something I found out today. The new External Dashboard
FAST XFI DASH DATA LOGGER
can also be used on the Classic Fast boxes with an adaptor cable. Not only will it datalog your passes, it will also allow you to datalog additional inputs like the XFI does. This means the Classic guys can log fuel/oil pressure, egt's, driveshaft speed, turbo back pressure, crankcase vacuum, CO2 pressure, yada, yada, yada.
Can you send me a quote to dtb400@msn.com.
I have a FAST sequential box with individual cylinder controll (old style not xfi). Am I right to assume this will work on my application?
Thanks,
Don Barnett
Am I correct in assuming that no tuning parameters can be changed with the external dash board? It is for logging only?
Tg
That is correct. It will also allow you to log additional analog inputs like the XFI does.
