I have yet to see any data from my probes, I was looking at the directions in the troubleshooting section and it states if 32 degrees F no communication from the module. Does it matter which pin get's yellow vs green when plugging into the wireing harness.
I've got power and ground and I have the resistor caps plugged in as well.
Further clarification the pin out indicates C9#1 high / C10#1 LO or C25 #0 high / C26#0 LO.
Which of these am I supposed to be using and which is high vs LO coming off the module. Yellow = hi or LO
Any assistance offered appreciated.
ok so yellow = high now which set of XFI pin in's do you use?
