Oct 3, 2005 #1 M Mad_Trbo Active Member Joined Jun 10, 2005 Messages 1,033 Just installing the FAST XFI system on the '87 turbo regal. Wondering how do you log knock, in other words what channel do I need to log? Thanks!
Oct 3, 2005 #2 D disco stu Active Member Joined Apr 10, 2002 Messages 2,562 ESC RTD. Be sure you have you ESC parameters set in spark functions.
Oct 3, 2005 #3 O Otto J Well-Known Member Joined May 31, 2001 Messages 10,546 go to file,dashboard setup,open the drop down menu and goto dashboard for logging,look for ESC rtd (*) and add it to the dash.
Oct 4, 2005 #4 M Mad_Trbo Active Member Joined Jun 10, 2005 Messages 1,033 That is what I figured, but doesn't this simply tell you what is being pulled in the form of timing as a result of the knock? Or does it tell you how many counts of knock are being encountered?
Oct 4, 2005 #5 O Otto J Well-Known Member Joined May 31, 2001 Messages 10,546 i believe just degrees.but you can see how much and how bad by looking at the datalog after.
