Fastest on stock MAF
BUICKTR
Just wanted to know how many people are running in the 10's with the factory MAF. I run 11.30's at this moment, but I wanted to know if it would still run faster with this MAF. :confused:
it will.....into the 9's for sure..I have a stock MAF (well, no cone, no screens stock MAF)
9's with the AC Delco MAF.:eek: That's very good!! I plan to just be in the mid 10's.:D
Has anyone ever built a deck using a 1/2" Drive Ratchet as a hammer? Just wondering. :D ;)
just saw a car lay down 491hp at the rear on the dyno this weekend. Had the stock MAF under the hood. Not sure if it was functional or not.
lots of fast cars with stock Maf....not necessarily the recommended route if you want to go real fast, but there are some real good chip guys out there
maybe Neal could chime in?
making enough power to run 10's..:D
still have stock maf with 1 screen still in it
new times nov 1st.;)
If Red's going 127 mph with a 1 screen stocker that's yikes fast.
Steve Yanklin can make a No screen, No venturi MAF work with Max Effort chip. With a 4" to 3" bellmouth in front of this setup, it flowed more than a screenless LS1 3.5" MAF (well over 1000 CFM).
I'm guessing this is how nines are possible.
The car Jeff H. AKA "SAYWHEN' drives to work once in a while run's 9.80's @ 135-137 on the stock modified maf.
Steve
I run 10.60's with a stock MAF and a max effort 16 position thumb wheel. I plan on going to the MAFless soon.
Steve,
I will contact you soon on the MAFLESS.
