I thought the air fuel being fat was causing me to have a slow boost condition but it seems as its real fat on the big end 10.0s of the scale fat. Cant figure it out because before i switched tp a front mount intercooler and 6776 turbo from the T64e it ran mint 11.3-11.6 all the war across the board. I checked all i can think of. I dropped the tank again to see if i had a line pinced all the lines look to be the correct way. the regulator is working fine it jumps from 45(vac on) to just about 60 (vac on) at around 20 pounds of boost. If im trieing to just get things sorted out on pump gas and its a tt race chip how much would it affect the running condition as far as breaking up ? I dont see any vacuum leaks. A little lost
Thanks Donny
Thanks Donny
